8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible), 100 guests, and 6 robots.
Topics128,064
Posts1,055,860
Members48,428
I am converting my 51-3100 to front disc brakes, keeping rear drum brakes. I bought a dual mast cyl adapter from chevy duty, but they couldn't tell me what master cyl to use with it. Is a proportioning valve required? Is there any tips or problems encountered with this conversion? Would appreciate hearing from you.
41 Chev 2dr coupe
51 3100 w/a 261
11 Camaro RS ragtop
Alan-
Way to go on the conversion. I am not an expert, but am in the process of getting a early 70's Nova drum-drum system in line. You'll need a master that can accomodate a residual valve for the rear drums. However, if the master is a dual chamber design, I do not THINK you need to proportion valve the whole set up. Other experts should affirm or contradict me on this point!
Consider master cylinders from vehicles with similar systems. My window is narrow, but there were certainly 70's GM cars with the disc drum set up. These are available from your local parts stores or other performance sellers, including Chevy Duty. Also, consider calling any of the brake upgrade folks for additional info (such as ECI, MP Brakes, Classic Perfomance, etc.) I had good experiences with ECI and Classic Performance.
Good luck!
A lot of good info on this brake facts site.
