3 members (Leo, Gdads51, 1 invisible), 171 guests, and 3 robots.
Topics128,088
Posts1,055,995
Members48,430
#918980 02/10/2013 10:13 PM
I've been looking at some gearsets for my 14 bolt. I'm wondering if anyone has ever tried U.S.A. Standard Gear or Superior Gear? The U.S.A is about 1/2 the price of the OEM or Yukon counterpart and the Superior is about 2/3's the price. I've heard the cheaper gearsets can be noisey, but some say it's all in how you set them up.
Any ideas?
Chris
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Chris, when you say "14 bolt", do you mean that cover has 14 bolts,
or the ring gear has 14 bolts, or the carrier is held in by 14 bolts???
Since I'm not into hot rodding those half stated terms always
cornfuse me. Seems like everyone has their own opinion on what
they are discribing. You know, 14 bolt, 9 bolt, 12 bolt, but what bolts??????
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
richmond gear is what use usually.what gears are you running now? going down or up? correct, only noisy due to set-up on tolerences.
denny, #of bolts in the cover.not an opinion, common terms.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Aha, Denny,
I know why neither of us knows what a 14 bolt is. And the later-post explanation is almost incomprehensible (complete sentences are lacking).
10.5” Corporate 14 Bolt Differential is a heavy duty differential that is used by Chevrolet and GMC trucks and vans since 1973. Of course it might have been a 14-bolt from 64 and later.
A good question from us would have been: "are you referring to a 9.5" or one of the 10.5" GM 14 bolt rear ends?"
I actually have both sitting here in the garage, but what I'm looking for is for a 73-85 10.5". Been looking around and Richmond, Yukon, and OEM seem to be at the top of the price range. Superior, Motive, and Nitro are middle of the road. U.S.A Standard is by far the least expensive.
Anyhow, I'm NOT looking for the cheapest, just the best value for the money. I'm only going to do it once.
Chris
"The Fake Truck"
hey, am i back in english class? my fingers can't keep up with my mind,so i use short incomplete sentences to get to the point. to answer the question, in my opinion richmond is the best for the money. (yea i know, no capitals in my posts either)
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
I used U.S.A. Standard Gears in my Jeep. The results work good. No gear noise. The only down side I saw was some runout on the pinion face. I used a pinion depth gauge and got .005 difference in measurement if I turned the pinion.
If you were not using a depth gauge you'd never know.
