5 members (homer52, TUTS 59, Wheelie, carbking, Otto Skorzeny), 118 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#917918 02/07/2013 12:54 AM
Has anyone used the heavy-duty Head light harness from LMC? How easy was it to hook up? Did you accually connect to the battery or the battery side of the regulator?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #919082 02/11/2013 1:17 PM
I have been building, as have many others here on the 'Bolt, this mod for years. The idea is to get battery amperage and voltage to the lights by the shortest route. It does make your headlights noticeably brighter. I use 12ga wire and ceramic connectors as well as connector grease. I get the relays on ebay. See the schematic in my photo bucket by following the link below. My way is better made with better parts then any kit I've seen, so DIY and save a few bucks!
Best wishes,
Les
