| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 48 'Bolter | | 'Bolter Joined: May 2011 Posts: 48 | My temperature gage climbs to 'hot' after engine warms up to normal operating temperature. I've replaced both the gage & sending unit. My next thought is printed circuit problems...suggestions? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Is your gauge aftermarket? I wouldn't think that a 1960 instrument cluster had a circuit board. Most temp. sensors I've worked on have an inverse temp/resistance curve. If yours is of that type, then a low resistance condition is appearing.
| | | | | Joined: May 2011 Posts: 48 'Bolter | | 'Bolter Joined: May 2011 Posts: 48 | No it's stock. Printed circuit on cluster | | |
