3 members (klhansen, tricordati, Pre '68 Dave), 91 guests, and 2 robots.
Topics128,096
Posts1,056,477
Members48,444
I am finalizing some wiring on my truck.
I have changed from lights to gauges. As well I am using a stock dash.
My question has to do with the way the ammeter is wired up.
Per the shop manual it looks like the hook up is this:
From the positive post on the battery to the starter (big red wire), there is then a black wire (18 ga.) that goes from this same connection through a couple of connectors to the back of the ammeter. Coming out of the back of this same ammeter connector is a black/white wire (18 ga.) that goes through a couple of connectors to the horn relay. The circuit seems to be completed as the horn relay is also connected from the batter via a red wire (12 ga).
The simple question: Is this correct?
It just seems to me that there would always be current flowing and thus drain the battery???
Just want to make sure I keep the smoke inside the wires (someone once told me that once you let the smoke out of the wires they quit working smile ).
Thanks in advance.
Simple answer, no.
It's a shunt type of ammeter, sounds like you have it wired correctly-it senses a difference between the starter connection and the horn relay connection-no real current going thru it.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
