| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91893 04/03/2005 7:34 AM | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | What are the correct in-gauge bulb specs (for gauge lighting and the various info functions) for a 54 on 12 volts? Thanks! Christian | | |
#91894 04/03/2005 3:59 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ohpants,
I think the numbers below might help. The first number is GM part number (I think). The number in parentheses is the bulb manufacturer's bulb number.
Tim
Instrument 6V 125588 (55) 12V 127934 (57)
Beam Indicator 6V 115273 (51) 12V 131282 (53)
Directional Signal Indicator: one of the above (I think I used a 53) | | |
#91895 04/04/2005 8:00 PM | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Thanks again Tim, I'll check them out. First time I ever used the brights the gauge filled with smoke-- PO had fitted an oversized beam bulb that pressed against the hole in the face. Guess he drove everywhere on low beams.
Christian | | |
