3 members (78buckshot, baldeagle, Rusty Rod), 109 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#91893 04/03/2005 7:34 AM
What are the correct in-gauge bulb specs (for gauge lighting and the various info functions) for a 54 on 12 volts? Thanks! Christian
#91894 04/03/2005 3:59 PM
ohpants,
I think the numbers below might help. The first number is GM part number (I think). The number in parentheses is the bulb manufacturer's bulb number.
Tim
Instrument
6V 125588 (55)
12V 127934 (57)
Beam Indicator
6V 115273 (51)
12V 131282 (53)
Directional Signal Indicator: one of the above (I think I used a 53)
#91895 04/04/2005 8:00 PM
Thanks again Tim, I'll check them out. First time I ever used the brights the gauge filled with smoke-- PO had fitted an oversized beam bulb that pressed against the hole in the face. Guess he drove everywhere on low beams.
Christian
