7 members (TUTS 59, 46 Texaco, EchoBravoSierra, UtahYork, jmoore, Otto Skorzeny, TexasA&M48Truck),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | I am replacing the wooden floor and need to replace the linoleum also. I need a roll approximately 5.5 feet by 7 feet. Does anyone have a reasonable priced source? Has anyone done this and does it look original? Please advise. Thanks. V/r, Nick Cavallaro, Bel Air, MD | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | NJC, You will want the bown linoleum. Call Tony at Battleship Linoleum and ask him to send you a sample and to send you an old magazine article on how to route the lines/ribs into the sheet. Make sure you ask about the material that is thick enough to route the lines/ribs into it. Do you have the wood floor removed already? | | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | Yes, floor is out and a new was built . Okay brown linoleum thick enough to make the original pattern. And I need the article to see how to make the linoleum like the old. Thanks Tim. NICK | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | There is no known source for the linoleum mat for the suburban at this time. There was a guy several years ago that was testing the waters to see if there was a demand for the material made to fit. He has disappeared from the board and I don't know if he ever produced the mat for our use.
You can make your own mat but it won't be cheap or easy. You will have to find a supplier that will sell the mat in brown/tan and the width needed. It has to be thicker than many of the products available. Then you will have to make a pattern from your floor, including the cut-outs for the seat mounts. You will have to set up a jig to route the grooves using the proper router bit so that they will look like the original pattern.
There is a guy that posts in Hemmings that make the matting for the chevrolet Nomad and other models that had similar matting, but I don't think he has attempted to make the matting for the suburban.
Good luck and if you find more information, please share here, there's lot's of guys that want the matting for there trucks too. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Others on this site,including myself would be interested in purchasing the rear mat.If you find a source and need more than one order to make it cheaper,let us know.Of course we will have to know all the details first.
The guy testing the waters,left us high and dry without any explanation.I gave him all my contact information and still heard nothing.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | http://s1278.beta.photobucket.com/user/njcavallaro/media/001_zps9eee6127.jpg.htmlEveryone, The linoleum was obtained from Tony at Battleship Linoleum. See link above. Then you have to make a way to put ridges in the linoleum. I used a dremel tool taped to an old drill jig. I posted a photograph. It is a lot of work and I would suggest doing it over several weekends and stop when you get tired. I made a few mistakes and hopefully the seat frames will hide it. Good luck. Thanks. V/R, Nick Cavallaro, Bel Air, MD | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Very nice, Nick
Am I correct in my understanding that two thicknesses of the brown/tan linoleum are available? What is the thickness of the linoleum you bought?
| | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | Tim, Tony only had linoleum about 2.5 sixteenth of an inch. Therefore you only make the slightest ridge depth. I used a 5 32d drill bit and no more than 1sixteenth depth. The linoleum cost three hundred ten dollars including UPS shipping. Tony gives instructions and extra pieces to play with. Thanks. Nick | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I think you mean 2.5mm. 2.5 sixteenth is .156, 2.5mm is .100 (approx.) and we don't describe things in 2.5 sixteenths in America, just the weirdo lumber world.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think the standard lino thickness is 3mm nowadays [0.118]
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Uni Walton line (solid colors) of Armstrong Linoleum is made two thicknesses: 0.100 in. (2.5 mm) and 0.125 in. (3.2 mm = 1/8"). I do not know if this is available in the USA and/or Canada. If anyone knows a north american retail source of this material in 3.2mm thickness in black (UP280) and in tan/brown (UP260), please post that information. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Uni Walton line (solid colors) of Armstrong Linoleum is made two thicknesses: 0.100 in. (2.5 mm) and 0.125 in. (3.2 mm = 1/8"). I do not know if this is available in the USA and/or Canada. If anyone knows a north american retail source of this material in 3.2mm thickness in black (UP280) and in tan/brown (UP260), please post that information. I am looking to finish my new plywood floor and this material looks like it will work. Has anyone researched this or found a distributer? If not I will pursue this myself. I wish someone would produce this! …...g | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks, Tim. I will check it further, I need the brown not the black. LPX260 I have a flooring guy, i will check with him on availability. ….g | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | George,
Battleship Linoleum used to have the brown in the thicker ply.
Are you going to route the grooves into the mat?
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I think I will try to router it myself, I have a friend that is a retired wood shop teacher, I will have him help me set up the router and make a jig. I have a few other ideas on making these that I am also going to pursue. It's getting the material locally that is going to be hard. Thanks again for the information………..g | | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | i also e-mailed the lino guy /seems like he gave up !!if anybody finds any info or linoleum /please some info !! id buy enough to do a 58 carryall ! thanks mike | | |
