Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#918383 02/08/2013 6:04 PM
took out 6 volt generator, want to install 12 volt alternator...for my 48 gmc, do i need to switch pulleys, alt. pulley slightly smaller, if so, is it much work?
696969 #918386 02/08/2013 6:09 PM
a smaller diameter pulley is preferable on an alternator [faster spin], what might be a problem is width, if it's a much narrower groove an original belt will likely be too wide, and while you may be able to get a narrower belt to work, you don't want the narrow belt to be bottoming out in the other pulleys .... play it by ear wink
