3 members (Nick in Manitou, Sjm, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91837 05/17/2004 2:55 AM | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | My wifes '53 Belair has an after market "looks original" AM/FM/Cassette player with a seperate power amplifier. If the radio is on, even with the volume down, the speakers produce a noise almost like my '66 C20's 4 speed whine!
Where's the best place to filter out this ignition noise? I think she's got the stock plugs for a 235.
The money I save as a mechanic, I spend on medical bills!
#91838 05/19/2004 2:50 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Is the noise from the ignition or the generator/alternator?. Have you tried disconnecting the generator/alternator and see what happens? Even heater motors can produce the same noise at times from the brushes. capactors on the output of a generator/alternator can get rid of most of that type of noise or adding a choke. May also check where the amp is getting it's power from, may have to run a wire off the battery throught a fuse may also help, can even add a relay to the acc terminal to torn off the amp with the truck. Ignition noise is another problem all together, check the cap and rotor for condition, and the type of plugs you are using may make a difference. See if you can fing a copy of the Radio Amateur's Handbook publish by the ARRL ( American Radio Relay League) quite a few of our public libraries have copys and have lots of information on noise problems with radios. | | |
