2 members (KEVINSKI, Dennys28),
96
0
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82931 09/18/2007 4:47 PM | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | Can anyone tell me what the differences are between a Stromberg BXOV-2 14-22 and a Stromberg BXOV-25 14-23? The only info I can find is the 14-25 has an electric choke (are these good?) but cannot find anything on whether the jets are the same. Thanks, Bob
1950 Chevrolet 1300
#82932 09/19/2007 2:25 AM | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | Still trying to find info on the jets. The more important question is if the electric choke will be a problem on a dual carb setup on my 261? Also, do the Stromberg BXOV electric chokes work well? Thanks again for the help, slowly I am learning more about these old trucks. Bob
1950 Chevrolet 1300
| | | | | Joined: May 2008 Posts: 2 New Guy | | New Guy Joined: May 2008 Posts: 2 | Hey Bob Did you ever get an answer to your question? I am considering the exact same thing except I want to put it on a GMC 228 with Hydra-matic | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the weber carbs Tom Langdon sells have electric chokes, he said they will work on 6 or 12 volts, and should work fine on a dual set up. I realize they are different carburetors, but I am not sure the electrical part knows that. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am using dual Carter-Weber electric choke carburetors on a 6v 261. The electric chokes (and the carburetors) work flawlessly (except for the two carburetors being too small for a 261.
It would be nice to hear from Stromberg BXOV electric choke users regarding the BXOV's electric choke.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Stromberg 14-22 and 14-23 have a different calibration.
And I would not want to mix them on a dual carb application (see lines 2 and 3 in my signature).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2008 Posts: 2 New Guy | | New Guy Joined: May 2008 Posts: 2 | Too bad... I have one of each 14-22 and 14-23 and a few misc Stromberg 1 barrels. It sounds like getting the 14-23 to match the 14-22 would be more complicated than just putting in a different jet or power.valve My 53 GMC has the original Hydra-matic and I kind of wanted to keep the electric choke. I guess I'll keep looking for a second 14-23 Thanks for the help | | |
