3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
#82931 09/18/2007 4:47 PM
Can anyone tell me what the differences are between a Stromberg BXOV-2 14-22 and a Stromberg BXOV-25 14-23? The only info I can find is the 14-25 has an electric choke (are these good?) but cannot find anything on whether the jets are the same.
Bob
1950 Chevrolet 1300
#82932 09/19/2007 2:25 AM
Still trying to find info on the jets. The more important question is if the electric choke will be a problem on a dual carb setup on my 261?
Also, do the Stromberg BXOV electric chokes work well?
Thanks again for the help, slowly I am learning more about these old trucks.
Bob
1950 Chevrolet 1300
Hey Bob
Did you ever get an answer to your question?
I am considering the exact same thing except I want to put it on a GMC 228 with Hydra-matic
the weber carbs Tom Langdon sells have electric chokes, he said they will work on 6 or 12 volts, and should work fine on a dual set up. I realize they are different carburetors, but I am not sure the electrical part knows that.
I am using dual Carter-Weber electric choke carburetors on a 6v 261. The electric chokes (and the carburetors) work flawlessly (except for the two carburetors being too small for a 261.
It would be nice to hear from Stromberg BXOV electric choke users regarding the BXOV's electric choke.
Carburetion specialist
Stromberg 14-22 and 14-23 have a different calibration.
And I would not want to mix them on a dual carb application (see lines 2 and 3 in my signature).
Jon.
The Carburetor Shop
Too bad...
I have one of each 14-22 and 14-23 and a few misc Stromberg 1 barrels.
It sounds like getting the 14-23 to match the 14-22 would be more complicated than just putting in a different jet or power.valve
My 53 GMC has the original Hydra-matic and I kind of wanted to keep the electric choke. I guess I'll keep looking for a second 14-23
Thanks for the help
