1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Wondering if the steering column can be removed from the steering box in order to update to a newer column and to move the stock box to clear a big block. Id really like to use the stock box. Anyone have any experience with this? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lunchbox, the steering column is not removeable other than by cutting/pulling the mast jacket off and modifying the shaft by cutting and adapting a "U" joint. You will have to move the box outboard quite a bit to clear a big block (if there is enough room to do that). There are other boxes that you could install in place of the original steering box, a lot depends on how hard you're going to work your larger truck, hope that helps. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Hey thanks 3b. So technically I could use my stock gearbox / a lower portion of the steering shaft (just a nub out of the box to attach a ujoint) by cutting the mast jacket off at the top of the box? Do you know of sources for other boxes (e.g. vehicles they would come from) that would work? Im not trying to beat up my truck as far as use is concerned, but would still like to be able to still use it as originally intended. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lunchbox, you will gain some clearance when the mast jacket is removed, but I don't know if you can move the steering box outboard enough to get the clearance you will need. There are kits available to mount later GM power steering boxes to the front of the left frame rail, but these are car or pickup boxes at best and I would be concerned that they were strong enough if you ever taxed the truck to its design limit. If you tried searching for "power steering conversion" you might find some tips, I think Grigg suggested a Toyota steering box, and quite a while ago an Isuzu NPR was mentioned, hope that helps. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Both Grig and I have used International scout boxes. We both had several pictures of our conversions unfortunately mine were lost to the take over of Web shots. I will have to take some new pictures and get a new posting sight. My convention was done on a 56 that now has a big block with long tube headers. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Oh we are not far from one a another I am in Roy just south of Tacoma drop me a PM if you would like to come and see the steering box and system mounted. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Hevyhauler. I will def come down to check out your rig. sounds alot like the direction i'm going with mine. I just found a couple isuzu boxes locally that i'm going to take a look at. I'll let you all know how it goes Joe | | |
