1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#918096 02/07/2013 6:01 PM
b10
Offline
I decided to put a new gasket on the exhaust and intake manifold to the block.I then decided to install a new gasket on the exhaust flange out to muffler.I turned manifold upside down on the work bench and noticed there is no heat riser only stove bolts in the holes where the shaft should be. I do not know how long it has been like that but i am sure DAD must have done it 50 years ago. Should i just leave it be or install a new one? Engine runs well on trips on the back roads (joy rides). Any feedback .Thanks
Ex Hall Monitor
Ex Hall Monitor
If it ain't broke don't fix it. If it's been running fine without it leave it alone. I've had mine jammed in the heat off position for years. A bit of choke on cold start, no problem.
Mine is missing too. Runs fine.
If it's broke hit it harder!
i tore all mine out and plugged them when i had the manifolds off the trucks. i have no issues adjust choke accordingly until enine is up to temp. or you could rip it apart, remove the sleeves if they ain't already and get a new one and install it.
b10
Offline
LET IT BE ,LET IT BE sounds good like the song.
b10 #918269 02/08/2013 10:05 AM
better gone than stuck in the closed position as mine was. ran ok but valves rattled under acceleration. moved mine to now stuck open position and runs great just may have to run with a little choke for a longer duration.
1952 Chevy Pickup Truck
Now lets see if I have this right,with the heat riser weight in the horazontal position that would be in the closed position?
Ex Hall Monitor
Ex Hall Monitor
This is the 'heat off' position. The terms open and closed are a bit confusing to me because both positions allow the exhaust to flow. Nothing's ever actually "closed". Heat on and heat off make more sense.
