| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | I am trying to identify the cam shaft which came out of my 39 gmc. The engine is a 228 cid and the P/N on the cam is gmc # 2191529. The engine ran fine after rebuilding it, but I could never time it to 5 BTDC. However, it would run if I advanced the timing. This is the first time it ran since I bought it. Also the vacuum was seady but low, about 12 inches, some of that may be the carb adjustment. If anyone has any suggestions or part numbers it would be appreciated. Thanks
Jim
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Could it possibly be a tooth off on the cam gears?
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hello jap. Welcome to the Stovebolt Page. I have a GMC 39-41 parts book covering models 100-460. The part # for the camshaft for the years and models listed above is 2136000. The numerical list of part #'s for 39-41 does not list your cams part #. Maybe someone can help with a newer parts manual. | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I show the '39 GMC 228 camshaft as 2193486 and they show only one for ALL 228-248-270 gasoline engines from '39 to 53
The number you gave I can not match with any GMC parts from '39-'59 | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thanks for the part numbers, I'm not sure where to go from here? I have a Motor's Truck Repair Manual, Second Edition, and it states # 1 at TDC and 90 degrees from the cam key way should be 13 teeth to the crankshaft gear mark, which it is. So according to the book its in time. Could flywheels be different from chevy's to gmc's and still fit? Thanks, jap
Jim
| | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Look no further than Inliners - 2191529 is not a part number, it's a casting number - and it's correct for your 228 GMC. | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Thanks for the link sixpack.  | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thanks for all the info and links. When I get to the root of this problem I will post the results.
Jim
