| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 3 New Guy | | New Guy Joined: Jan 2013 Posts: 3 | I just bought a 61 Chevy apache 20 with a 235. well it ran but found that it was putting water in the oil. So i pulled the engine took the head off and found that number one piston wrist pin had worked it self out of its original position and made a nice deep groove in the cylinder wall, all other cylinders are good and the head is cracked between the valves. So what am asking is the 235 a good engine and if so im in nebraska and cant find parts or another engine. Need help. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . So what am asking is the 235 a good engine and if so im in nebraska and cant find parts or another engine. Need help. Welcome to Stovebolt.com The 235 is a good engine. Check the Swap Meet - Parts For Sale. Or, place a Want Ad in the Swap Meet. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Rambo,
There's a 235 on Craig's list for $350 in air park in Lincoln. Check the junkyards they are all over.
Tom
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | There should be plenty of 235cid engines about, May I suggest if you are going to replace a engine look for the larger 261cid. Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | If the block is good other than the wrist pin damage you can get it sleeved. The 235 was used in a lot of different Chevys for years, there has to be engine in your neck of the woods.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I think the supply is drying up. Lots probably ended up as scrap iron.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2013 Posts: 3 New Guy | | New Guy Joined: Jan 2013 Posts: 3 | Been looking on craigslist and havent found any, And yea when iron price was up a while back everyone took almost everything to scrap. I remember driving by farms and jusnk yards an seeing alot of old trucks and now not so much. But will keep looking. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 |
| | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | I have a 61 235 W/side mounts turns free came from a running vehicle it does have the 848 small chamber head also. I am in Northeast Ks | | | | | Joined: Jan 2013 Posts: 3 New Guy | | New Guy Joined: Jan 2013 Posts: 3 | Well I just found another engine I think its a 261 its out of a 1962 c60 straight truck Here are the numbers from behind the distributer (F0509LB) Can anyone help.
