| | | Forums66 Topics128,211 Posts1,057,477 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Today I cleaned grime and paint off the case and found a number stamped on the case top on the flat rearward edge. I am guessing it is a serial number???
The number is DO 21911
It's on a '46 half ton, that I believe is original to the truck.
A google search for a decoder turned up zilch. Any ideas? | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | http://www.gmheritagecenter.com/doc...hevrolet-Trucks/1946-Chevrolet-Truck.pdfp 49 on serial numbers explains your question. (scroll down 7 pages) DO = regular Muncie on 3100. 21911 is production number. Numbers started at 1001 at each plant.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Randy Thank you---holy smokes that was a fast reply!!! | | |
