12 members (klhansen, KEVINSKI, cmayna, Peggy M, Bill Hanlon, Gdads51, tclederman, qside, Hanks custodian, mick53, 2 invisible),
126
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | My 1942 1.5 ton has 700x20 steer tires and 750x20 rears. I would like to use all the same tire on the truck. I assume the 750's would fender rub if used on front? In spring i will mount a rear tire on front, Just wanted to see if anyone knows already. Thanks, Mike. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can do whatever you want, as some PO did, the sizes you have now aren't OE, but sizes varied with GVW ratings - the 7.50's will be fine on front afterthought: I had 8.25's all around on my 46 because they were easier to find than 7.50's at a good price, and the steers just barely touched at full lock turns Bill | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | I did the same thing on my truck ('46 2 ton). The info I found when I was shopping tires (which was years ago) said that both 7.50's or 8.25's were used. All I could find were 8.25's so that is what I used. They do rub just a little on a full turn but not bad. They fill up the front fenders nicely. | | |
