0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
I am switching my manual transmission '66 C10 from a manual transmission to an automatic. I am also adding power brakes. While I believe the manual trans brake pedal and arm will work fine, I was wondering if the automatic used a different (wider) pedal than the manual trans one. Also, did vehicles with power brakes use a different pedal cover than the manual brake units? If so, where can I purchase both items?
Crusing in the Passing Lane
I have a 64 with a powerglide, the pedal is identical to a stick shift pedal
Currently cruising
in the Passing Lane
Rest in Peace
Great! Does anyone know if the '66 is the same as well?
Also, did the power brake pedal cover say "Power Brakes" ?
The pedals are the same manual or auto. All they did is remove the third pedal. You can remove the third pedal as well and the brake pedal will work just fine without it.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
The pedal assembly is the same and the brake pedal area, is the same, as the manual brake pedal. The wider brake pedal came after 1966. The brake pedal pad, will have POWER BRAKE (no S) on it.
