5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#91749 07/17/2002 9:46 PM
My '67 C-10 (V-8) has the guage package and the temp. sending unit is missing. I think the guage is fine as it jumps around when grounded at the other end of the lead. What I can't seem to find is a replacement sending unit and where on the engine it belongs. I think it goes in the T-stat housing.
Any help would be appreciated.
Beat to fit, paint to match
#91750 07/18/2002 6:45 AM
Normally the unit is on the left head, between #1 and #3 plugs, has a single contact that uses GM female spade and slotted black cover. Idiot lts sender is 2 wire. Sender may be on rt side between #6 and #8.
57 3/4 ton rat
66 C-10 panel 350 200R4 3.07 axle
68 C-20 dump runner, 250 4spd, 4.11
82 Camaro, 305, THM-200-R4
84 Monte Carlo, 350, TH350
EVERETT, WA
