| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91749 07/17/2002 9:46 PM | Joined: Jan 2002 Posts: 24 Member | | Member Joined: Jan 2002 Posts: 24 | My '67 C-10 (V-8) has the guage package and the temp. sending unit is missing. I think the guage is fine as it jumps around when grounded at the other end of the lead. What I can't seem to find is a replacement sending unit and where on the engine it belongs. I think it goes in the T-stat housing.
Any help would be appreciated.
Beat to fit, paint to match
#91750 07/18/2002 6:45 AM | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | Normally the unit is on the left head, between #1 and #3 plugs, has a single contact that uses GM female spade and slotted black cover. Idiot lts sender is 2 wire. Sender may be on rt side between #6 and #8.
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
