4 members (Goach2, greenie-reddy, Pete O, klhansen), 76 guests, and 2 robots.
Topics128,172
Posts1,057,038
Members48,458
Mornin,
So after rebuilding the carb, the generator, new fuel pump, changing the oil, a few new gaskets here and there, we got her to fire up and run.
http://www.flickr.com/photos/ajporsche/8443668848/in/set-72157632234070092
There's a few small leaks to deal with, but overall I'm pretty happy. I can't imagine what's going on inside this engine, crusty oil and water, bearings that haven't seen any lube for years, and moving parts that are dry. I'll have to run it a few more times and keep flushing the water I think till I decide if it's really good or not. I'm thinking the water pump is toast, but before I buy a new one, I'll run it a few more times. I'm not driving the truck yet, I still have to install the new fuel tank and deal with the brakes a little more. I'm pretty excited though, definitely a major milestone.
I'm the guy in the yellow hat wink
~Dave
I don't think I'll ever grow tired of watching 1st start videos!
It sounds good. I wouldn't worry about whats going on inside of the engine. 5 years isn't that long.
Oh that is special music! That is a great video and a neat old truck. I started mine after 17 years of sitting outside. It kind of smoked a bit!
I think I saw a wild turkey walking along in the background during the video.
1951 1 Ton Completed
Thanks guys!
I ran it again last night and I'm "pretty" sure the water pump is bad. Something in the front of the engine is grinding really bad. I've changed enough water pumps to know that it's probably bad by the sound of it, but maybe, besides leaking, is there any other way to find out for sure? A new one for the 228 is $150, so I'd like to be sure. It sure idled nicely last night. I got the carb adjusted a little better, fixed the valve cover leak, and tightened down the radiator hoses a little better.
I actually sat in the cab while it was running and went thru the gears a bit. Good to know the clutch is working and everything is turning properly. The brakes work too even though they still need some bleeding. I don't have the wheels on it and it's up on jack stands.
Oh, and I got the new gas tank in. I POR-15'd it and it looks beautiful. All new fittings and hoses to it as well. One more thing crossed off the list.
Thanks again for the comments,
~Dave
If you start it up without the fan belt off, the water pump wouldn't be turning. Maybe that might help.
Good idea! I'll try it!
~Dave
Moderated by  Dusty53
