3 members (PEB56er, Phak1, 1 invisible), 182 guests, and 4 robots.
Topics128,090
Posts1,056,382
Members48,442
Ex Hall Monitor
Ex Hall Monitor
My ammeter has started lying to me. I'm wanting to put a voltmeter in the car but all I can find are 12v voltmeters. Is there a quick & simple way to convert a 12v voltmeter to 6v?
There is no way to do that. Do the 12 volt meters have graduations around the 6 volt mark?
1951 1 Ton Completed
Yeah Richard, as long as it’s a D’Arsonval meter movement and not a digital meter a 12v
meter should work just fine. The only negative is that you won’t have as good as
resolution as you would if you had one that was calibrated for 6v.
Now if you were going in the other direction and applied 12v to a meter move that was
calibrated to 6v you would peg the meter and take a good chance of bending the needle.
Just compare the idea to the range switch on a multimeters.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
The problem is the minimum readout on a 12v is 8 volts (some are 9v). It would be pegged to the bottom side all the time, doing me no good.
Yeah, see your point now Tiny. I haven't looked for an analog
automotive voltmeter for half a century so I'm totaly unaware
of what's out there.
Industreal supply like Grainger has square analog panel meters
0-15vdc made by Simpson but they are real pricy.
If all you want to do is take a sampling of the output voltage
then I'd opt for a cheap digital miltimeter. Other wise if
you're looking for a permenent setup it looks like you're in
for a lot of searching and a place to spend a big buck if you
do find one.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
Jerry turned me on to a 0-8 analog meter on ebay. I have a bid in on it so we'll see what happens.
