1 members (klhansen),
65
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My ammeter has started lying to me. I'm wanting to put a voltmeter in the car but all I can find are 12v voltmeters. Is there a quick & simple way to convert a 12v voltmeter to 6v?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There is no way to do that. Do the 12 volt meters have graduations around the 6 volt mark? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Richard, as long as it’s a D’Arsonval meter movement and not a digital meter a 12v meter should work just fine. The only negative is that you won’t have as good as resolution as you would if you had one that was calibrated for 6v.
Now if you were going in the other direction and applied 12v to a meter move that was calibrated to 6v you would peg the meter and take a good chance of bending the needle. Just compare the idea to the range switch on a multimeters. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The problem is the minimum readout on a 12v is 8 volts (some are 9v). It would be pegged to the bottom side all the time, doing me no good.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, see your point now Tiny. I haven't looked for an analog automotive voltmeter for half a century so I'm totaly unaware of what's out there.
Industreal supply like Grainger has square analog panel meters 0-15vdc made by Simpson but they are real pricy. If all you want to do is take a sampling of the output voltage then I'd opt for a cheap digital miltimeter. Other wise if you're looking for a permenent setup it looks like you're in for a lot of searching and a place to spend a big buck if you do find one.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Jerry turned me on to a 0-8 analog meter on ebay. I have a bid in on it so we'll see what happens.
