1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Folks I got my '63 C10 last year. It's a nice driver. Was restored 15 years ago and could use some body work next winter. It has a newer 350 and 700R4. When I tackle the body job I would like to also rewire. Those 50 year old wires and connections are causing me grief! I don't plan to add any power options. What is the best wiring kit for me? -OldsCool | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "Best" has to be defined. The best quality, diagrams, instructions, most extras, complete kit is American Autowire. Around $465. The best price is not American Autowire. EZ, painless and others are quite a bit "bester". I have used AAW and I have done my own from scratch. You can buy wire, connectors and contacts that are just like the kits. BUT you have to have a good schematic and a good understanding of wiring. The 63 will be a bit more complicated than the 55-59's I do.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i like the ezwire it has good instructions have used them in 5 trucks with no problems | | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Antique Chev Parts (my closest dealer) carries the American Auto wire but its on the pricey side at $770. I think I could order the EZ quite a bit less. Not sure I need all that the AW will include since I am not adding electrical load. Leonard, did the EZ include new bulb sockets, dimmer switch,...what components do you think I would need to add to the EZ for a basic rewire? Thanks, OldsCool | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Look up rebel wiring and i think they have a 15% discount for the stovebolters.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Thanks guys. Even with shipping fees that ebay price is better!I'll check out Rebel too. -OldsCool | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Keep an eye on E Bay for a bit. I bought a Painless Universal Truck kit for $ 150. Good quality / well marked / good tech support if you get stuck. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | the ez wire comes with the headlight plugs. and all the plugs to plug into a later model gm keyed column it has directions to wire it for a dash key. i buy the gm wire ends that lock in the plugs and reuse the stock plugs. i also buy the 21 circut and what wires i do not use i roll up next to the fuse pannel in case i want to add on power instructions are good and the wires are marked every 6" | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | I bought a kit from Speedway when I did my 49. It was the 18? circuit so I had plenty of room to add power door locks and stereo, etc. It was well marked and included everything I needed. I had never wired anything from scratch and rolling out all those coils of wire was a bit daunting but the instructions were very good and it wasn't all that hard if you follow instructions and just take it a step at a time. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We use: M&H Electric Fabricators, Inc. www.wiringharness.com
