Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Otto Skorzeny, DennisM, TUTS 59, Woodcmiami, UtahYork), 91 guests, and 4 robots.
Topics128,281
Posts1,058,479
Members48,490
#9160 03/02/2004 10:39 PM
Does any one know if I could use a 1971-78 camero rear end on my 55 2nd series chassis? And would it take a lot of work to get it done?
I am going to put a disk brake conversion kit (71-78 camero) on the front and I would like to keep it all one year and make of car. I also want a narrower rear end to put on wider tiers. The guy at the Salvage yard recomended a 64 Impala rear end.
#9161 03/02/2004 11:44 PM
Hamon-
Is it pronounced "Hey-mon" like a greeting from the Carribean?
Seriously, check out this ChevyTrucks.org page for a handy rear-end table or two.
Looks like your pick-up would be 62" flange to flange and a '71 Camaro comes in at either 60" or 61-1/2". Pretty close, but getting out the tape measure on both donor and recipient will be the test.
#9162 03/03/2004 5:21 AM
If its possible , why not take the rearwheels off (if it has any now) and maybe even remove the rear axle completely . then you can slide in a pair of wheel/tire combo's you want to use and see if they will clear the frame and fenders . get them blocked into the right spot and measure the inside to inside axle width off of the wheels , then you can see what you will need to make this combo work .
#9163 03/04/2004 4:07 PM
No its short for Hamonthabone
#9164 03/04/2004 4:50 PM
thanks Ham-on
Had a chance to check the rear?
