1 members (DES57),
119
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | What's wrong with long threads? More info the better and good to encourage discusion and get the detail of what has worked for others. I want to know it's got a high probability of working before spending a couple hundred dollars and having to start over. That doesn't go over well with the other half! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I check in on this thread every now and then and seems like much of the same discussion over and over, nothing wrong with long threads though.
I understand wanting to do the research and get it right the first time, I do my best to do the same. many times it works, sometimes not. At some point you still have to do something though, can't research it forever.
If you're still not so sure what'll work trying stuff is the next step. Junkyard parts can be real cheap, and if it works rebuild it if necessary/desirable or replace with new.
Grigg | | | | | Joined: Jun 2010 Posts: 8 New Guy | | New Guy Joined: Jun 2010 Posts: 8 | My $0.02,
Do NOT use a smaller bore mc than original mc, you won't get a good pedal and won't be safe. When switching to dual circuit mc and staying with 4 wheel drum manual do NOT use a power brake mc (shallow hole), use a deep hole manual brake mc. I made the $50 mistake of using a smaller bore mc, it stopped the truck but did not have a good pedal / not safe. You will bleed them brakes forever thinking its air in the lines, but it too small of a bore mc. Been there did that.
1949 Chevy 3800 1956 Chevy 6400
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | thanks. im down to using the .125 corvette master with residuals or whatever power master wbrown used.
grigg- i know you are right. i have a tendancy to draw things out especially if i know its gonna be a while till i can work on the solution....
cab and front fenders came off tonight! a little more tear down and its time to put everything back together! | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I saw your photos Tj_M. You are a long way from getting this truck on the road. Get it all put back together and ready to drive then the brake issue can be dealt with. I thought you had this truck on the road. And...now that I see it's a dually that changes everything. Those rear brakes have 2 wheel cylinders in each wheel right? | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | I'm pretty sure it's still 1 wheel cylinder per corner on a 1-ton. manual Maybe it's a bit ambitious but i'm hoping to have my frame ready to start bolting parts back on in a month and a half or so. With time for feedback on here and finding parts/shipping etc. I wanted to start talking now. I'm not planning on waiting till it's close to driving to do brakes. I'll do them as one of the first few things after rolling chassis is clean. that way I have easy access for running brake lines. | | |
