0 members (), 73 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
I have a 48 1/2 ton 3100 short bed with the 3spd column shift 6cyl 235. I found a 47 1/2 ton with the 3spd floor shift trans ,casting # 591195 I have to check to see if the splines are the same but , my question is,` I can get the trans, torque tube and rear for the swap but could I just switch the transmissions ?? or do I need to swap all ?? I know the trans floor cover will need to be changed and maybe a floor shift steering column later, anything else ??
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
The bolt pattern for the trans to bellhousing changed from 1947 to 1948, so you would need the bellhousing, trans, and torque tube
assembly(47 is longer than 48-54 due to the shorter trans).
My Blog
