Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (dt235sd, J Lucas, Hotrod Lincoln, Rich'sToys, 1 invisible), 113 guests, and 6 robots.
Topics128,290
Posts1,058,559
Members48,492
#915306 01/28/2013 10:29 AM
I've got a set of good looking 12v trailer lights that I'd like to use on my 50 6v truck.
I ordered 6v bulbs, which have a single contact point.
The light housings have two contact points.
May I make these work by putting a small piece of copper foil in the light fitting to connect both terminals to the single terminal bulb?
Thanks! Dickson
1950 Chevy 3100 short bed
1951 GMC 3/4 ton long bed
Dickerson -
Don't jump the contacts. Throw away the single filament bulb and buy a #1154 dual filament 6v bulb. You may have to shop around to find one.
I believe that a wire for the tail light and a wire for the brake light were run to the tail light assembly in 1950. There may have been separate sockets in the original assembly for each or may have been a single dual filament bulb. Makes no difference --- solder the brake wire to the "bright" filament contact wire of your trailer light assembly and solder tail light wire to the "not-so-bright" filament contact wire of your trailer light assembly.
Make sure that the body and/or bracket of the trailer light assembly has a good ground to the truck.
> 1950 wiring diagram
> Chevrolet 1950 Truck Specifications - Tail & Stop Lights
> NAPA #1154 6v dual filament bulb
> The Truck Shop bulbs
> Reproduction 1950 tail light assemblies
- Lonnie
My '54 3104
Lonnie -You're great. Thanks for the help!!!
