3 members (DadsFirstPickup, Hotrod Lincoln, Gib70), 103 guests, and 3 robots.
Topics128,089
Posts1,056,366
Members48,442
#915117 01/27/2013 4:58 PM
1 Offline
I have a good block from a 1937 216. I also have a guy that has a 1940 216 with a cracked block. Can he rebuild his motor with my block? Besides the potntial piston size issue, is there anything else?
Trombones Totem Poles And Old Trucks!
No. 1940 was the first year for a rear main seal, so the block and crank are completely different.
The flywheel went from 4 bolts holding the flywheel to 6 in 1940 also.
My Blog
He would need to use your block and crankshaft assy. I'm pretty sure you can get away with the rest, then I hope you have an early flywheel as has been pointed out .
I'm not sure where in Wa you are but I'm sure I can come up with a 40 engine.
PM me if interested
My Blog
