7 members (GMCJammer51, TexasA&M48Truck, 55shaker, Gdads51, Pre '68 Dave, moparguy, 3B), 106 guests, and 3 robots.
Topics128,091
Posts1,056,390
Members48,442
#915117 01/27/2013 4:58 PM
1 Offline
I have a good block from a 1937 216. I also have a guy that has a 1940 216 with a cracked block. Can he rebuild his motor with my block? Besides the potntial piston size issue, is there anything else?
Trombones Totem Poles And Old Trucks!
P Online: Content
No. 1940 was the first year for a rear main seal, so the block and crank are completely different.
The flywheel went from 4 bolts holding the flywheel to 6 in 1940 also.
My Blog
He would need to use your block and crankshaft assy. I'm pretty sure you can get away with the rest, then I hope you have an early flywheel as has been pointed out .
P Online: Content
I'm not sure where in Wa you are but I'm sure I can come up with a 40 engine.
PM me if interested
My Blog
