0 members (),
73
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | I was replacing the throwout bearing on my clutch and when I had the driveshaft off my buddy noticed that the front u joint felt a little 'lumpy". Upon further inspection we noticed two little nylon inserts holding in the cup. When I was looking at the shop manual I did not notice these inserts. He remembered ujoints on 70's and 80's trucks having these, but not 50's. And he recalled they were a pain to work. Do any of you recognize these? I ordered a replacement ujoint from Jim Carter but if a PO replaced these ujoints with non-original/stock will my new ujoints fit? I am not sure how to attach pics or I would. The inserts (I scraped one with a screwdriver and it was red) show up a little dots on the joint.
Second question is that we also noticed the the joint sleeve yoke (fitting into tranny) had been epoxied or something by a PO. I'd like to find a replacement yoke but they are tough to track down. Does anybody have any clues where I might track one down?
Thanks again to everybody for helping.
1956 Apache 1959 Apache 1966 DeVille
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | how they came from the factory isn't how replacements have evolved to be - likely they've been replaced in the past, probably could get new ones at NAPA .... for the yoke w/ slip sleeve you'll probably have to find used to get the coarse spline, but you might check NAPA, they're the same to about 67/8
Bill | | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | Thanks Bill, I will check NAPA for the yoke.
