1 members (klhansen), 126 guests, and 3 robots.
Topics128,131
Posts1,056,726
Members48,454
#913976 01/23/2013 10:51 AM
I got a 235 motor out of a 1954 New Port Beach fire truck. The casting numbers are typical but the stamped numbers next to the distributor are unusual. S0405XH Can anyone help with this?
310054 #914047 01/23/2013 4:20 PM
photobucket The donor
310054 #914668 01/25/2013 8:27 PM
Can you post some of the typical casting numbers.
-Tom
1950 Chevy 3100 w/ 1956 235
310054 #914669 01/25/2013 8:31 PM
Or even some pic's of the engine.
My Blog
310054 #914671 01/25/2013 8:39 PM
the head number is 3836848
behind the starter number is 3733949
next to the fuel pump number is CON3C148
310054 #914676 01/25/2013 9:00 PM
the head is a 56-62 235 head
these are bad guesses:
the block is a 1955 code?
C148 looks like a 1958 date code?
S0405XH
Here are 1958 engine codes.
S should be a plant - a T or an F
XH ?
310054 #914678 01/25/2013 9:05 PM
Yea the numbers strange.
Thanks for the try
310054 #914680 01/25/2013 9:08 PM
This truck also had an antifreeze filter with a glass tube in the hose as a sight glass.
310054 #914683 01/25/2013 9:20 PM
S could be a Service replacement engine, I've seen the S code on later engines that were service replacements. Not sure about the XH code, though.
BTW, the donor truck you hav pictured is a '51, rather than a '54.
Bill Burmeister
310054 #914701 01/25/2013 10:21 PM
51 on the outside 54 on the inside. The guy I got it from said all the paper work and manuals were 54.
310054 #914712 01/25/2013 11:20 PM
If the dash gauges glass is not recessed over an inch, the radio hole is on top of the dash, the speaker slots run horizontal not vertical, and it doesn't have a one piece windshield, it's a 51 on the inside also.
Evan
310054 #914717 01/26/2013 2:43 AM
Your engine code is certainly a puzzle.
The date code on your 55' block seems to decode as March 14, 1958. Not a problem if you believe that GM periodically cast older style parts at later years. See this discussion about the same numbered block (3733949) with a date code of J129 (Oct 12,1959)ending with David Hayward, automotive historian, supporting that idea.
http://www.chevytalk.org/fusionbb/printpost.php?tid/260623/
Back to your original question. First, the format of the engine code as engine assembly plant, month, day, series/designation, (S0405XH),didn't appear until 1957.
Next, the first letter "S" should stand for "Saginaw" or "Saginaw Service".
Several Nova/Camaro/Chevelle sites stated this but I could find
no other online references to this as an engine assembly plant. (Years this plant was operational?)
http://www.nastyz28.com/sbchevy/sblock.php
Next, the 04 and 05 are obviously month and day.
Finally the suffix XH. When limited to 235 truck engines, the suffix X appeared in only the 54-56 years I believe. In years 54 and 55 there was only X, XA, and XB noting regular production 3100, 3600, and 3800 models. In 56 we go from X to XGC but never quite to XH. So, rather inconclusive.
So we have a 55' block, cast in Mar 58' with the engine assembled later than that at a service engine assembly plant?
I hope someone else can add to the engine replacement process during this time.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
310054 #914728 01/26/2013 6:46 AM
Bill & Randy,
Thanks for the posts, and for the information on the S prefix.
I think that Greg Hill & Warren Foster (WD was his "handle") found a 261 block that had a lot of very odd characteristics. Warren (a GM parts professional/expert) mentioned something about it being a later replacement block.
310054 #914754 01/26/2013 10:00 AM
I would like to see a pic of the stamping. A lot of times numbers are misread.
My Blog
310054 #915075 01/27/2013 12:59 PM
photobucket Here you go
310054 #915105 01/27/2013 4:09 PM
It almost looks to me like there is a ghost stamping in the pic.
I wonder if your block has been restamped.
My Blog
310054 #916608 02/02/2013 8:23 AM
hey not to but in on some one else question but i am having casting issues to cant find what meas besides year and what z means trying find more my block number is 0840658F54Z and what kind fire truck you working on im doing a 43 chevy american lafrance
310054 #916611 02/02/2013 8:35 AM
310054 #916621 02/02/2013 9:02 AM
will a tranny from a 40s model 216 work with the 235 if i take off ones on there now?
310054 #916631 02/02/2013 9:43 AM
What year/type 40s transmission?
What year/size truck do you want to put it into?
310054 #916634 02/02/2013 9:50 AM
it is a 43 chevy fire truck and its 4 speed on floor and the 235 will be going into the truck but want to use tranny from the 40s but the tranny from the 235 is three on tree
