7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi Everyone,
Pardon if this is a silly question but in the attached picture you will see a crossmember that has a home made transmission mount on it. Is this crossmember stock or should I cut it out when I put the new driveline (stock) in? The Truck is a 1955 first series.
[IMG
1955 First Series 3100
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy mendonjo, No that is not a stock crossmember, that transmission is probably out of a 1958 - 64 Chev car. Truth be told that crossmember probably isn't really necessary, plenty of stock newer trucks with longer transmissions than that one, with no crossmember supporting them. Just remove that when you make your changes, hope that helps. | | |
