| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Hi all. I hope I am not repeating a previous question but I tried and could not find in previous threads. Has anyone replaced the frames for the rear side slider windows in a 1961 suburban (I assume 61-66 are the same). Does anyone sell aftermarket frames or do I have to build them myself. Has anyone had to build these and if so, how did you do it. Any suggestions wuld be very much appreciated. Dale
Remember, for every mile of road, there's two miles of ditch! If you fall on your face, you're still moving forward.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | They look to be fairly easily re-made, but I ended up buying a set from Aridzona-and they are like new. I have not seen them reproduced, prolly not enough demand. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I found a Suburban in a junkyard in South Carolina... It's an 8 hour round trip, but they could be had if you want to buy rather than build.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Thanks guys. I may have to fabricate them.
Dale
