| | | Forums66 Topics128,129 Posts1,056,695 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | I got a 235 motor out of a 1954 New Port Beach fire truck. The casting numbers are typical but the stamped numbers next to the distributor are unusual. S0405XH Can anyone help with this? | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Can you post some of the typical casting numbers.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Or even some pic's of the engine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | the head number is 3836848 behind the starter number is 3733949 next to the fuel pump number is CON3C148 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | the head is a 56-62 235 head
these are bad guesses:
the block is a 1955 code?
C148 looks like a 1958 date code?
S0405XH
Here are 1958 engine codes.
S should be a plant - a T or an F XH ?
| | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | Yea the numbers strange. Thanks for the try | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | This truck also had an antifreeze filter with a glass tube in the hose as a sight glass. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | S could be a Service replacement engine, I've seen the S code on later engines that were service replacements. Not sure about the XH code, though. BTW, the donor truck you hav pictured is a '51, rather than a '54.
Bill Burmeister | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | 51 on the outside 54 on the inside. The guy I got it from said all the paper work and manuals were 54. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If the dash gauges glass is not recessed over an inch, the radio hole is on top of the dash, the speaker slots run horizontal not vertical, and it doesn't have a one piece windshield, it's a 51 on the inside also.
Evan
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Your engine code is certainly a puzzle. The date code on your 55' block seems to decode as March 14, 1958. Not a problem if you believe that GM periodically cast older style parts at later years. See this discussion about the same numbered block (3733949) with a date code of J129 (Oct 12,1959)ending with David Hayward, automotive historian, supporting that idea. http://www.chevytalk.org/fusionbb/printpost.php?tid/260623/Back to your original question. First, the format of the engine code as engine assembly plant, month, day, series/designation, (S0405XH),didn't appear until 1957. Next, the first letter "S" should stand for "Saginaw" or "Saginaw Service". Several Nova/Camaro/Chevelle sites stated this but I could find no other online references to this as an engine assembly plant. (Years this plant was operational?) http://www.nastyz28.com/sbchevy/sblock.phpNext, the 04 and 05 are obviously month and day. Finally the suffix XH. When limited to 235 truck engines, the suffix X appeared in only the 54-56 years I believe. In years 54 and 55 there was only X, XA, and XB noting regular production 3100, 3600, and 3800 models. In 56 we go from X to XGC but never quite to XH. So, rather inconclusive. So we have a 55' block, cast in Mar 58' with the engine assembled later than that at a service engine assembly plant? I hope someone else can add to the engine replacement process during this time.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bill & Randy,
Thanks for the posts, and for the information on the S prefix.
I think that Greg Hill & Warren Foster (WD was his "handle") found a 261 block that had a lot of very odd characteristics. Warren (a GM parts professional/expert) mentioned something about it being a later replacement block.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would like to see a pic of the stamping. A lot of times numbers are misread.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It almost looks to me like there is a ghost stamping in the pic. I wonder if your block has been restamped.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | hey not to but in on some one else question but i am having casting issues to cant find what meas besides year and what z means trying find more my block number is 0840658F54Z and what kind fire truck you working on im doing a 43 chevy american lafrance | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | will a tranny from a 40s model 216 work with the 235 if i take off ones on there now? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year/type 40s transmission?
What year/size truck do you want to put it into?
| | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | it is a 43 chevy fire truck and its 4 speed on floor and the 235 will be going into the truck but want to use tranny from the 40s but the tranny from the 235 is three on tree | | |
