1 members (Nick in Manitou),
70
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | I have a 50 Chevy PU that I am resto-moding. The truck has its original springs that were de-arched in the mid-90's. I want to stay with a leaf spring system but wondering if I should consider changing out the springs with some new Posies or Chassis Engineering. I want to drop the rear end about 4 inches and go with 20 inch wheels. What is the quality of the aftermarket springs? Are these USA made or China made? Is one better than the other or is there another manufacturer I should consider? Any help would be appreciated. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Thanks, Garandboy for the leads. I just finished dropping the leaf springs and found that the rear hangers that are riveted to the frame are out of round. These hangers hold the shackles which secure the tail end of each leaf spring. I can find new replacement shackles but not the hangers. Did you run across this problem in your case? Any ideas where I might find a replacement hanger? | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | I had that problem on one hanger but I found a bunch of NOS ones so I'm good for a longgg time. do a post in the parts wanted forum and somebody should have some. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Thanks again. I will do that right now. Hopefully I will find one available. 73scoutcrawler suggested that I weld up the hole and redrill it. Did you ever consider that option? | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | no, it easier and safer to find a new one and bolt it in with grade 8 bolts. | | | | | Joined: Mar 2010 Posts: 9 New Guy | | New Guy Joined: Mar 2010 Posts: 9 | Try eatonsprings.com for American made springs. They are a GM authorized shop and also give good advice. Lots of good spring info on their site too. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Old Yeller,
Are you sure the forged hanger is worn? Or is it just the pressed-in threaded bushing? If so, new bushings come with the new shackles.
regards,
Leon | | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | I'm from st louie and St louis spring has been around for a long time. used to be able to get them to make springs to your specs for a fair $. Might be worth a call if for no other reason than to discuss options with someone that does this for a living.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I bought a new set from TCI,complete,with new mounts,shocks and shock mounts,and pads to flip the rearend.Just by flipping the rearend you will lower your truck about 3 inches.I am now running 5 leaf springs instead of the original 7 leaves.The truck rides and handles excellent.If I remember right the whole kit cost me around $600.Money well spent.Also my truck is a 1955 2nd series,which came with the rearend mounted below the springs. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | You are correct Leon. The worn part was the pressed in bushing which I have now replaced. Thanks for everyone's help with my dilemma. | | | | | Joined: Jan 2013 Posts: 1 Moderated | | Moderated Joined: Jan 2013 Posts: 1 | Were you ever able to fing those hangers? I am in the same position with my 49 3100, I have a great explorer rear end,found some good donor springs, have u-bolts, etc., yet need to figure out the hanger situation. I do not want to buy one of the $500.00 "kits" when all I need from it is the re-designed hangers. | | |
