2 members (Shaffer's1950, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Have a rebuild kit from Novak. I pressed out the old countershaft front bearing and the one in the kit is way loose. I did not need to press it in and I can move it freehand
Is this normal?
I have to doubt it
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 79 | There were two different countershaft bearing sizes, the smaller being the most common. it should be a snug fit. You will just need to get the numbers off the old bearing and get one that way. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | The kit comes with two and the smaller (2412) one is enclosed on one end and would never fit.
the larger bearing in the kit is snug -
I see that the larger one comes as a 1206 or 2414
The one I took out was 1206 - as is the one Novak sent.
I will use loctite bearing as the previous post noted.
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | What is odd is that the kit came with
(2) Countershaft Front bearings (2412 and 1206) 1 Countershaft Rear
and three others 6307, 6209 and 6208 - for 2 spots
I may be a bit slow on the take, but I find a parts list, or better instructions would have been helpful from Novak. The OLD CHEVY Manual is 10 times better
It wil be trial and error on those three bearings on the main shaft
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't get confused by the extra parts. The same kit is made up to encompass all of the models. You will have some left over parts. It's still better than having to chase down all of the parts separatly on your own. All you have to do is match up the old bearings with ones that come in the kit from Novak. DG
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Looks like the only part I am missing from my "transmission in a bucket" is the Oil Deflecter for the rear countershaft bearing.
I found one at Collectors Auto Supply fo $10.
Once I get a spanner wrench ( i think it is 1 1/2 inch) I should be cookin with gas
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Or, you can make one as I did using a piece of heavy wall tubing, some 1/2" rod and a couple of dowl pins. http://www.pbase.com/dennygraham/image/137529461 Denny G
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Clearly Denny knows the concept when they say "Necessity is the mother of invention".
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Only wish I had an "inventors" mind Dave. My bathroom reader for this month is a book by Ronald Clark titled "EDISON, the man who made the future." Now there was was one inventive individual.
Denny G
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Well Thomas Edison was a regular user of Vin Mariani and of course he did not have 300 channels of TV to distract him.
We all have Edison potential - we just opt not to indulge in cociane and alcohol, instead we watch Dancing with the stars and Nascar | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | So that spanner nut is on there with some force. I know it is left hand threads - but boy it is tough to crack. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, that's why the 1/2" levers are on the one I made, came right off with the spanner I have pictured.
DG
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I used some 1/4 inch steel and drilled a 1 3/8 hole in the middle, tapped in two 1/4 inch steel bolts on each side.
But just bending the bolts - I had SS bolts and will now try hardened steel.
I also went to a local Drivetrain shop and transmission shop - both did not want to try and get it off - afraid of screwin it up.
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | So that did it - a knuckle buster- - no off the shelf Spanner wrench was gonna get that off.
I am thinking of using some loctite on that nut when I put it back together. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Then you'll have one heck of a time getting it off the next time. No need for Loctite just snug it up as tight as you can get it with your spanner. Oh and by the way, that was why I used the dowel pins.
Denny G
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Anyone have a pic on how the rear oil seal is on the sm420?
I scanned denny's site but did not see the seal | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | is that seal only used in NON-Torque Tube applications?? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I believe you have a '53, 3100? There is no rear seal in the SM420. Check you fluid level in the trans several times once you start driving it till it stabilizes.
Denny G.
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I see part 48 in the exploded view here sm420 View - 1954 Yes I have a 53 so maybe this does not apply | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is only used on open drive shaft transmissions.
