| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 26 | Im wiring my dash cluster of gauges now and im confused about there the wires go on the posts like the amp gauge and gas, temp gauge, i know which wires go there but i dont know which posts are pos or neg? like in the amp gauge, i dont want to cross the wires, ive got the dash facing me when i started wiring it so if anybody can give me the info ill be puttin the wires in from that position, thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the year and make of truck? Is it the original voltage?
| | | | | Joined: May 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 26 | It's a 1959 3800 model 1ton with a replacement oem wiring harness I'm using the original dash and gauges | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you have the factory wiring diagram, the orientation shown is labeled for the colors, note the line that says "front of dash" and put yourself in the drivers seat - the pass or driver side of a gauge is as shown Bill | | | | | Joined: May 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 26 | Ok I think I'm on the right track , but I still need to know where the red wires go on the amp gauge ? There should be 2 red and one black if I'm lookin at the gauge do the wires go red for the charge side and black for the discharge side of the gauge? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | red to the charge [drivers] side by the diagram
Bill | | |
