2 members (Barry Martak, Wally / Montana), 167 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
Junior Member
Junior Member
I recently replaced my generator with an alternator. Since then I have been blowing through batteries like crazy. Is it possible to have a positive ground system and run an alternator? I have the thick red wire connected to the positive post on the battery, the black wire connected to a switched source, and the white is jumped to the the alternator post the red wire comes off of. If not, how hard is it to convert to a negative ground? Thanks in advance for any help/suggestions.
cmil, have you checked the voltage your alternator is putting out? A high voltage will not be good for the battery. I suppose you could run an alternator in a +ve ground set-up but you might have to isolate the alternator and run the case to the -ve side of your wiring system and the output to the +ve ground.
Positive ground alternators are available, but they're scarce and expensive. Since practically everything produced since 1957 is 12V negative ground, there's no sense in trying to rig up a positive ground system, IMHO. You might have a shorted voltage regulator that's overcharging the battery. Max voltage against a well-charged battery should be around 14.7 volts. Higher than that, and you'll boil the battery dry, and ruin it in a hurry. Also, be sure the body and engine are well-grounded, especially if you're using an early-type alternator with a remote regulator mounted to the body. I've seen bad grounds cause full alternator output, even with a good regulator.
Y
Junior Member
Junior Member
Y Offline
to switch to negative ground first disconnect battery switch wires on dash, voltage or amperage gauge switch wires on coil connect battery to negative ground.
Chuck
Forgive me if this seems a dumb question, but are you running a 6-volt or 12-volt battery?
