4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#913118 01/20/2013 12:33 PM
Im wiring my dash cluster of gauges now and im confused about there the wires go on the posts like the amp gauge and gas, temp gauge, i know which wires go there but i dont know which posts are pos or neg? like in the amp gauge, i dont want to cross the wires, ive got the dash facing me when i started wiring it so if anybody can give me the info ill be puttin the wires in from that position, thanks
panmanhd #913119 01/20/2013 12:35 PM
What is the year and make of truck?
Is it the original voltage?
panmanhd #913128 01/20/2013 1:01 PM
It's a 1959 3800 model 1ton with a replacement oem wiring harness I'm using the original dash and gauges
panmanhd #913170 01/20/2013 3:11 PM
if you have the factory wiring diagram, the orientation shown is labeled for the colors, note the line that says "front of dash" and put yourself in the drivers seat - the pass or driver side of a gauge is as shown
panmanhd #913227 01/20/2013 7:23 PM
Ok I think I'm on the right track , but I still need to know where the red wires go on the amp gauge ? There should be 2 red and one black if I'm lookin at the gauge do the wires go red for the charge side and black for the discharge side of the gauge?
panmanhd #913230 01/20/2013 7:29 PM
red to the charge [drivers] side by the diagram
