1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#912503 01/17/2013 2:19 PM
My 56 3600 has the parking brake on the drive shaft. The pads on the drum are completely worn out making the brake basically non functioning.
I've looked in my parts catalog and no one seems to offer parts for this set up. Is it after market? dopes anyone know where to get parts?
3B Offline
Hy shoedog81, you should be able to send it to a good brake shoe rebuilder and have it relined. Try looking on Google for a friction material supplier, or contact your favorite F.L.A.P.S. and ask them where they would send it for relining, hope that helps.
There is a place in Spokane that does it. Pacific is the name I think, Vary reasonable.
1937 Chevy 1/2 ton panel
Got mine relined at local FLAPS. KOI Auto Parts
I wonder how that brake gets worn out? Do you think the previous owner used it to stop?
1951 1 Ton Completed
Thanks for asking that question, truckernix.
Driving while forgetting to release?
That's what I'm thinking. It is worn down all the way to the metal in some spots, I'll post some pics up in a bit.
Mechanism
what's left of the Pad material
I found a local shop to reline the friction material. They asked me what thickness the material should be. I told them 1/4 inch but I really have no idea. Anyone know what the factory thickness was?
Service manual says friction material is 2.25 by .25. Had the shop reline to those specs and it's too thick. Can't even get the brake band on the drum.
$70 down the drain
I doubt that the brake was worn out by using it to stop the vehicle with because they were about as effective as dragging your feet. My guess was that someone forgot to release it and drove it until smoke came up through the floor board. That happened quite often.
