1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Read somewhere about 261's using a double acting thermostat. Anybody know of this? Mine had the "regular" 180 degree thermostat. Want to do it right | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you'd have to find where you read that and figure out what they mean, all thermostats are "double acting" in that they open above a certain temp and close below that temp, there is nothing different about one for a 261
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The term is used here on Tim's site. double acting thermostat | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | ryanz,
What year is your 261?
The thermostat (Dole Pellet Bypass) and housing on my 1960 261 is different in style from other 235 thermostats that I have seen (Harrison Poppet Ball). I put a 235 thermostat and housing on that engine in my 1954 Suburban.
