3 members (j05h79, Phak1, Jay R), 73 guests, and 3 robots.
Topics128,154
Posts1,056,837
Members48,456
Read somewhere about 261's using a double acting thermostat. Anybody know of this? Mine had the "regular" 180 degree thermostat. Want to do it right
you'd have to find where you read that and figure out what they mean, all thermostats are "double acting" in that they open above a certain temp and close below that temp, there is nothing different about one for a 261
1960 261 thermostat specs found here in "Specifications 16-20" section. (Second page from the end of this compilation)
http://www.canadianmilitarypattern.com/1960%20235-261%20Engine%20Manual.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
The term is used here on Tim's site. double acting thermostat
1951 1 Ton Completed
ryanz,
What year is your 261?
The thermostat (Dole Pellet Bypass) and housing on my 1960 261 is different in style from other 235 thermostats that I have seen (Harrison Poppet Ball). I put a 235 thermostat and housing on that engine in my 1954 Suburban.
