Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (jasrking, 216wny, TexasA&M48Truck, MNSmith), 26 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
When I purchased my 65 C10 Custom Cab Fleetside the previous owner had bought an extra motor and transmission and threw it in with the sale. I check the casting number on the block (3896944)and determined it was a 283 from 1967. Is there anyway to determine specifically what type of vehicle the motor came from (i.e: Truck, Nova, Chevelle, etc)? The motor has a generator and not an alternator. I thought I had read somewhere that the alternator replaced the generator in 1965. I am getting ready to sell the motor and transmission and I'm trying to gather as much information on it as I can.
3B Offline
Hy bargy1, the alternator replaced the generator in 1963 in Canada. There should be an alpha/numeric code stamped into the block in front of the right head, if you post that we might be able to identify the original application for the engine, hope that helps.
Same in USA, alternator took over in '63.
BC
1960 C60 pasture art
3B, the alpha numeric code stamped into the block in front of the right head is V0608G0. All of the 0 are the same shape but I am not sure if they are zeros or the letter O.
3B Offline
Hy bargy1, that code does not appear in my 1968-74 motors manual, so someone else will have to help us identify the original application for your engine, sorry about that.
Looking at my decoder ( www.nastyz28.com ), engine was built in Flint, MI June 8, 1967 283, 195HP, 2 BBL, and used in full size or Camero vehicle.
1940 Chevy KC 1/2-Ton
Wouldn't be a 1967 Camaro, smallest V/8 was a 327 2 barrel, rated at 210 HP.
Brian
1955.2 3100 Truck
_________________________
Britcom,thank you for the decorder link. I followed the various charts and came up with the same conclusion (Flint, MI June 8 1967, 283, 195HP, 2 BBL and used in a full size or Camaro vehicle). There is a column in the chart labled APPL where it lists glide and A.I.R. I assume glide means it had a powerglide transmission but what does A.I.R. stand for? Any idea?
3B Offline
Hy bargy1, A.I.R. stands for Air Injection Reaction I believe, a smog pump by any other name. I am definately not sure when they started with that stuff, but 67 seems early to my memory.
