| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91252 12/18/2002 5:04 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I got a 6v starter with the original foot pedal trigger for my 270. The truck has been modified prior to me owning it with a 12v system. I have been told that I can run the 6v starter off the 12v system without too much worry.
I need to get the proper ignition coil to go with this new starter and I am not sure if it matters if I get a 6v or 12v. Can anyone help me with this?
Thanks in advance.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#91253 12/18/2002 6:31 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Your starter will be fine, it will just start the engine faster than it would with 6v. You definately want a 12v coil and a ballast resistor to protect the points. There's a good overview of the conversion here . I went with a single wire alternator and replaced the entire wiring harness; quicker starts, brighter headlights, electric wipers all make the truck more user-friendly. | | |
#91254 01/03/2003 4:20 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Bluebird, Get a 12v AC Delco 1 #12337166 coil not internally resisted. I did my conversion 8-9 months ago and boy, what a difference. Yes my original foot starter has never responded so fast before : - )
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
