1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#91232 03/19/2002 4:32 PM
While taking apart my speedometer for refinishing, I broke the pin that attaches the needle to the internal mechanism. Am I screwed or can these be replaced? Thanks.
#91233 03/26/2002 9:33 PM
Junior Member
Junior Member
Yep...I did this too...I was able to fix mine with a piece of the "straw" from a WD-40 can.
Just slip the straw over the leftover stub of the needle and then slip this onto the remains of the needle in the speedo case.
Took a lot of trial and error to get the length of the straw just right...I also put a small dab of glue in each end of the straw to hold it all together.
If yours is a clean break at the speedo with no stub, then I can't help.
