| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91215 05/01/2004 1:33 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Is it correct that the voltmeter (49 Chev 1/2 ton) is nothing more than an in line device that measures voltage in the electrical system? Therefore if I am eliminating the gauge,(replacing with aftermarket)can I just connect all of the existing wires going to the exisitng gauge together? The new gauges will get their power off of a new line from the ignition terminal on the ignition switch. Thanks, | | |
#91216 05/01/2004 5:42 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Yes
Joe
#91217 05/01/2004 7:48 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Voltmeter? I though those models had an ammeter! A voltmeter would be installed from hot to ground, and connecting those wires together would create a dead short! Jerry
#91218 05/02/2004 3:41 AM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Hotrod, you're right it is an ammeter. In my case though, the connections I'm asking about are all "hot", starter switch to ammeter, ammeter to fuse block and ammeter to alternator, so I think I'm still ok, I think. | | |
#91219 05/02/2004 4:52 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Hrockwell: Assuming it is an ammeter that your are considering replacing with an after-market voltmeter, it may not be a direct replacement. Ammeters measure current flow and often (not always) are to some degree in-line with current flow. Voltmeters measure a voltage (or potential) drop across a resistance. Many times they are set up to measure from some point in a circuit to ground. Ammeters and voltmeters measures different things, even though those things are related, current and voltage respectively. As a result they are usually wired differently. However, replacing the ammeter with a voltmeter is not a big deal, you may just need to re-wire a little bit depending on your current setup. | | |
#91220 05/02/2004 7:26 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | OK, now we're on the same page! Most older ammeters have a "shunt" built in, which carries most of the current, bypassing the meter movement, which only needs a few miilliamps to function. Simply tapping all the wires onto one terminal, or eliminating the meter and replacing it with a voltmeter isn't a problem. If you're going to an aftermarket ammeter, you'll need to follow the manufacturer's wiring diagram to make it indicate properly.
As long as your voltmeter (if you're using one in place of an ammeter) is connected to a source of straight battery voltage, such as the "ignition" or "accessory" terminal of the ignition switch, it should read battery voltage anytime the switch is on. Connect the other voltmeter lead (usually the "-" terminal) to a good ground, and you're in business! Jerry
#91221 05/03/2004 2:38 AM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Thanks all for the guidance. I'm replacing my stock gauges with new units from Classic Instruments. The new gauges are pretty straightforward to hook up. I was concerned about making sure that the rest of the electrical system is still in order. | | |
