1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
Any special tricks or tools I would need to install a new gasket on my 59. Having a heck of a time. Have tried using a soapy solution on the gasket which was of little help. Any advise would be appreciated. Thanks. Ken
Ken in NY
Is the rubber over 90 degrees F? I was just installing some grommets and a little heat makes a bunch of difference to pliability. I haven't gotten to the headliner yet so no help from a been there done that here.
Give me ambiguity
or give me something else
Haven't tried heating the gasket, but I will. Thanks for the advise. Will post results here.
Any other thoughts?
Ken in NY
Hi kb2tha,
I remember having a very difficult time getting mine installed too. I used a large screwdriver wrapped in duct tape to persuade it into the slot without scratching paint. Haven't tried it, but soaking the gasket in hot, soapy water seems like it would help.
Brian
1955.2 3100 Truck
Thanks for the information all. I won't have enough time to devote until Friday, but will post my results. My headliner is actually a piece cut from a van ceiling at the scrap yard. I will have to cut back the thickness around the perimeter.
Ken
Ken in NY
Petroleum jelly (vaseline) worked for me. Also it was about 90 in summer when we did it. Lots of patience, small block of wood and a rubber mallet!
No update yet. It has neen near or below zero here and on top of that I have been sick as a dog going on 9 days now. Thanks for all the replys. They should help. Ken
Ken in NY
Moderated by  ndkid275, Phak1
