| | | Forums66 Topics128,050 Posts1,055,684 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Any special tricks or tools I would need to install a new gasket on my 59. Having a heck of a time. Have tried using a soapy solution on the gasket which was of little help. Any advise would be appreciated. Thanks. Ken
Ken in NY
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Is the rubber over 90 degrees F? I was just installing some grommets and a little heat makes a bunch of difference to pliability. I haven't gotten to the headliner yet so no help from a been there done that here.
| | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Haven't tried heating the gasket, but I will. Thanks for the advise. Will post results here.
Any other thoughts?
Ken in NY
| | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi kb2tha,
I remember having a very difficult time getting mine installed too. I used a large screwdriver wrapped in duct tape to persuade it into the slot without scratching paint. Haven't tried it, but soaking the gasket in hot, soapy water seems like it would help. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Thanks for the information all. I won't have enough time to devote until Friday, but will post my results. My headliner is actually a piece cut from a van ceiling at the scrap yard. I will have to cut back the thickness around the perimeter. Ken
Ken in NY
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Petroleum jelly (vaseline) worked for me. Also it was about 90 in summer when we did it. Lots of patience, small block of wood and a rubber mallet! | | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | No update yet. It has neen near or below zero here and on top of that I have been sick as a dog going on 9 days now. Thanks for all the replys. They should help. Ken
Ken in NY
